radiator problem
Old Sep 12, 2010 | 08:16 AM
carlos84's Avatar
Default radiator problem
The male end of the radiator on the return line has snapped any suggestions?
Old Sep 12, 2010 | 08:21 AM
lipadj46's Avatar
you can try to tap the hole and epoxy in a threaded brass hose barb or take to a radiator shop (if they exist, you may need to call some shops and ask who they send their radiator work to) and they may be able to replace the top. Otherwise new radiator time.
Old Sep 12, 2010 | 11:53 AM
carlos84's Avatar
Thanks just finished, works! I dont know what I would do with out this forum.
Old Sep 12, 2010 | 01:41 PM
Carlos, better order a new radiator, when that nipple breaks off the plastic is fatigued from heat and will not hold, causing it to blow again and possibly damaging your engine.
You can buy good after market radiators for around $200, stay away from used ones cause they are usually plugged and or have e brittle plastic.
Sdavis
Mar 29, 2013 04:00 PM
Sdavis
Mar 28, 2013 10:08 AM
TOM R
Jan 17, 2013 09:25 PM
brianb883
Jan 12, 2010 02:49 PM
Doak
Nov 18, 2006 10:24 AM
