Radiators
The SAI trucks have a sensor threaded into a bung in the passenger side tank that tells the computer if the engine is cold enough to need the air injection for the catalysts. Most radiators now come with a threaded plug so that they work for both SAI and non-SAI trucks. If you have the sensor you remove the plug and install it otherwise you just leave the plug in place.
