Radiators
Old Feb 10, 2014 | 09:26 PM
roverwoody's Avatar
Default Radiators
I on eBay and I came across same good priced radiators. In some of them description, is spec is for Without Secondary Air Injection. What does the SAi have to do with the radiator?
Old Feb 10, 2014 | 09:47 PM
Dan7's Avatar
It's the wired plug at the bottom by the outlet hose. If the radiator is w/o sai, it won't have the threaded port there.
Old Feb 10, 2014 | 10:14 PM
roverwoody's Avatar
Will anything (hose, sensor, etc) be inserted in the plug?
Old Feb 10, 2014 | 10:39 PM
04duxlr's Avatar
The SAI trucks have a sensor threaded into a bung in the passenger side tank that tells the computer if the engine is cold enough to need the air injection for the catalysts. Most radiators now come with a threaded plug so that they work for both SAI and non-SAI trucks. If you have the sensor you remove the plug and install it otherwise you just leave the plug in place.
roverwoody
Sep 21, 2014 10:02 PM
acg
Jul 9, 2014 12:40 PM
Savannah Buzz
Nov 15, 2012 09:59 AM
Savannah Buzz
Sep 16, 2011 07:20 AM
Savannah Buzz
Off Topic
Jul 28, 2011 04:42 AM
