Radio Code Question - continued
Old Feb 3, 2009 | 01:00 PM
larry99discoI's Avatar
4wd High
Default Radio Code Question - continued
After I leave the radio on for an hour...
Is the radio code entered straight in, or do I need to press Mode or some other button first?
Old Feb 3, 2009 | 01:01 PM
Suede's Avatar
Default RE: Radio Code Question - continued
Just enter it straight in. If the code is correct, the stereo will work immediately after entering the last code numeral.
Old Feb 3, 2009 | 01:02 PM
okdiscoguy's Avatar
enter it straight it. You don't have to enter anything else
Old Mar 6, 2009 | 08:08 PM
roverohio's Avatar
Put a new battery in today and I am having the same issue. Called and got the code. Entered code and radio flashes but nothing happens. waited an hour tried again with same results..Any tips?
Old Mar 6, 2009 | 10:44 PM
Suede's Avatar
Sometimes the code can't be looked up correctly with the VIN number. Remove the radio and make note of the serial number on the tag on the rear. Call the dealer and ask him to look up the code based on the radio's serial number instead of the VIN number.
Camdisco24
Aug 8, 2008 08:36 AM
bitter356
Jul 17, 2008 09:16 PM
Camdisco24
May 15, 2008 07:41 AM
fitch11
Feb 18, 2008 05:56 PM
audiurq
Feb 15, 2007 03:42 PM
