Radio Removal.....
Old Apr 13, 2008 | 04:26 PM
Our1stDisco's Avatar
Default Radio Removal.....
On a 1999 Disco II. I see that there are slots in the bottom of the unit. I am assuming that these are for some sort of lock release tools. Ford had this for many years and you could simply use a coat hangar to do the trick. I have the regular radio system in the truck, capable of CD changer, but not one in the truck. I plan on installing an aftermarketCD changer myself in the truck and was curious to get the radio out of it so I may plug in the FM modulator inline with the antenna. Thanks in advance.
Preston
Old Apr 13, 2008 | 06:42 PM
Default RE: Radio Removal.....
Make sure that you have the radio codes.
I think that the radio has input jacks on the back. Not sure if you have the Pioneer or Alpine deck, but you can get a CD changer that will plug-N-play with factory unit.
http://www.roverlandparts.com/index....mp;Category=72
Old Apr 13, 2008 | 06:48 PM
Urban Panzer's Avatar
good piccys of the stereo keys you need here (assuming you have an Alpine Unit)
https://landroverforums.com/m_55949/mpage_1/key_/tm.htm
Old Apr 13, 2008 | 07:01 PM
okdiscoguy's Avatar
I was looking for that post to show him....
To the original poster, you can find a good used changer that will plug into your existing harness on E-bay for a lot cheaper than adding a new one. Plus, it goes direct intput instead of modulation. You will get better sound...
Old Apr 13, 2008 | 07:30 PM
gtagg's Avatar
Just take 2 wire ties and push them in the slots and gently pry it out. comes out pretty easy. I wanted to hook up my ipod took about 20 minutes.
gTAGG
Old Apr 13, 2008 | 09:40 PM
Yes, I have the Alpine head unit and I alredy have a CD changer that I have had for a couple of years. Will the wire from the unit plug into the stereo?
Mark G
Oct 4, 2007 11:38 PM
Mark G
Oct 4, 2007 11:01 PM
ZMayo85
Aug 31, 2007 11:46 PM
dofbft
Oct 27, 2006 03:26 AM
rockridesva
May 17, 2006 08:05 PM
