Radio Removal
Old Aug 29, 2018 | 05:06 PM
Jeff NYC's Avatar
Default Radio Removal
Hello,
Is it possible to improvise the key which is required to remove the radio? There are two slots. My cassette is not operational and I utilize an Ipod connector. 2003 Disco 2 130k miles
Thanks,
B well,
Jeff
Old Aug 29, 2018 | 05:11 PM
Jeff NYC's Avatar
Sorry as I did not read the earlier posts on the subject.
Tnx
Old Aug 30, 2018 | 07:16 AM
mollusc's Avatar
Use the metal tabs from a hanging file folder.
Old Aug 30, 2018 | 07:26 AM
CollieRover's Avatar
Use the metal tabs and PULL! That SOB is in there right.
Old Aug 30, 2018 | 05:32 PM
Jeff NYC's Avatar
Thanks guys,
i will attempt in the am.
best,
jeff
Old Aug 30, 2018 | 06:11 PM
razorkill12's Avatar
I just used a coat hanger shaped similar to tool.....took like 30 secs to get radio out
Old Aug 31, 2018 | 09:47 AM
Jeff NYC's Avatar
Default Radio removal
Thanks guys,
The metal tabs from the file fit but not to be obtuse. Is there a latch which disengages? I hear a click and pull from the cassette deck but no movement. How far does the "key" need to be inserted?
B well,
Jeff
Old Aug 31, 2018 | 10:00 AM
Red5's Avatar
Old Aug 31, 2018 | 10:09 AM
Jeff NYC's Avatar
Thank you for the video. I would be lost without these u tube repair vids although I did not see this one on line.
Best,
jeff
mollusc's Avatar
It can be a bit tricky if you've never seen the top of the radio before. As shown in the video above, all you're doing is pressing down on a couple of spring latches. I don't try to pull the unit out using the tabs; I slide them in and pull on the unit using the tape slot instead. Usually have to wiggle it around getting each side free separately.
Disco TN
Mar 23, 2009 11:44 PM
Disco2Guy
Jun 29, 2008 07:48 PM
bluther
Oct 18, 2007 11:31 AM
Mark G
Oct 4, 2007 11:01 PM
JMCPilot
Jan 1, 2007 08:37 PM
