Radio Stays ON & Cigarette Lighter outlet Issues
Old Oct 16, 2023 | 07:07 PM
macutan's Avatar
Originally Posted by macutan
Thank you for this, I didn't know if the 1.5D was in mm or mm^2 for the Land Rover Schematics. I also felt that 16AWG was a thicker wire than the one i can currently see installed but I guess it won't matter much.
I'm including below the outlet USB socket I decided to go with, this includes an ON/OFF switch so when I wire it to an ALWAYS hot fuse I can decide to keep it OFF (or ON). I do not use this vehicle much so having the ability to cut power to the outlet may safe me from potentially emptying the car battery (though unlikely).
I am happy to report that I was able to identify the issue I was having with the wiring arriving to the cigar outlet, somehow I must have had a bad ground connection, I was able to locate the earth point (by the passenger A-Pillar) and wiggle the wiring there a little and bam! got the power back on at that outlet. Now I only have to wait for this USB outlet to arrive and will rewire it.
Thank you for this suggestion! I am so thankful to this community for posting very useful mods and hacks that we can include to these amazing vehicles!
Off to carry on trying to figure out what is wrong with the radio not turning off when I turn the ignition OFF.
One more question on your Add-A-Circuit, why does it have two fuses (a 20A and a 15A) connected to it ?
Old Oct 16, 2023 | 07:38 PM
macutan's Avatar
Originally Posted by Discorama
Pull the radio, leave the cables connected! and put the positive probe of the multimeter (negative connected to ground of course) directly into the connector holes. Check if there is 12V at the "permanent battery feed" (C0098-4) and that 12V goes on and off with ignition at the "auxilary feed" (C0098-7). The radio should turn off as soon as there is no voltage at the "auxilary feed". Maybe there is a shortcut or someone messed with the wiring.
Thank you Discorama for this!! I missed this radio pin-out from the Workshop Manual in the RAVE books!.
So, I performed the checks you indicated above with the below observations (I included photos at the end of this post):
  1. "permanent battery feed" (C0098-4): reading 12.34V (with key OUT of the ignition).
  2. "auxilary feed" (C0098-7): reading 242.1mV (with key OUT of the ignition).
  3. "auxiliary feed" (C0098-7): reading 12.24V (with key IN the ignition on position I).
I guess, the above confirms that the wiring to the radio is OK and the fact that the radio does NOT turn off after ignition position is at 0 (or even when key is OUT of the ignition) may be due to something going on on the radio itself, perhaps there is something wrong with the "RADIO ON/OFF" switch shown in the diagram below?
What should I try next?
Permanent Battery Feed (C0098-4) (key out of the ignition)
auxilary feed (C0098-7) (key out of the ignition; ie ignition position 0)
auxilary feed (C0098-7) (ignition position I)
Old Oct 17, 2023 | 08:56 AM
mollusc's Avatar
Make sure you test with the plug removed from the radio. Sometimes voltage can pass from always-on pins back to other pins via internal circuits.
Old Oct 17, 2023 | 09:00 AM
Discorama's Avatar
Looks like something is wrong with the head unit internally. The schematic for the head unit is a symbolic representation only. You would need the schematics from Alpine. Does the power button work in general? The easiest way to sort things would be trying another head unit.
Old Oct 17, 2023 | 07:43 PM
macutan's Avatar
Question
Hi ​​​@mollusc , Thank you for the suggestion. I have just done that and i am getting the same behaviour (see photos below).
Hey ​​​​@Discorama, thanks for the follow-up I agree, the power button works and everything else on the radio works as normal, it is ONLY the function of turning off when I take out the key from the ignition, may not be very important for some but i have forgotten to switch off the radio off just before i go on trips overseas and I come back to a drained battery after a couple of weeks.
I don't have another head unit to swap it and check it so, I'm taking it apart (see below).. I have no idea what I am doing though. Any suggestions on what to check or measure with the multimeter?
Old Oct 18, 2023 | 02:44 AM
Discorama's Avatar
To track it down you need the schematic from Alpine (I don't have it either and it is nowhere to find). It gets even more complex, because the unit is controlled by a microcontroller with software. The only thing you can do is to measure continuity (resistance or "beep mode") of the connections from connector to PCB, especially for the pin in question (C0098-7) and to inspect for broken connectors, broken PCB traces and bad soldering points visually. If something is disconnected the software might behave weirdly (not turning off and - as I understand your problem - it doesn't even turn off after the 20 min timeout).
Old Oct 18, 2023 | 02:27 PM
macutan's Avatar
Thank you @Discorama I'm going to try my luck with Alpine USA Technical support and plead my case. perhaps they feel pity on me and they can send me some tips or even schematics, though me trying to fix a bad solder in that tighly packed circuit will be a long shot, may end up biting the bullet and buy a used (same) alpine unit... (but it will pain me to receive one and experience the same issue).
Thanks for your posts on this, I am learning a lot about this amazing vehicle.
Old Oct 18, 2023 | 02:33 PM
mollusc's Avatar
I think I have a spare head unit you can have if you just want to replace it.
Old Oct 18, 2023 | 03:07 PM
macutan's Avatar
Will send you a PM! Thank you!
Old Oct 19, 2023 | 03:41 AM
Discorama's Avatar
Let me know if you were able to get your hands on some schematics. I am interested too, since I built my own unit and needed some info on the internals for correct interfacing. So far I could figure out some parts by reverse engineering the schematics from PCB, but having the manufacturer's would have been great. In case you are interested in my DIY head unit: https://landroverforums.com/forum/di...d-unit-107501/ Unfortunately, I can't make it in numbers and offer them for sale, because it would get too expensive.
