Radio volume doesn't work
Old Mar 5, 2019 | 03:55 PM
DennisG's Avatar
4th Gear
Default Radio volume doesn't work
Radio works and can barely hear the volume. The volume control doesn't work on the radio or the steering wheel. Any suggestions to fix ???
Old Mar 6, 2019 | 06:48 PM
Pa Taket's Avatar
There are a few different radio head units used on the DII; what model year, and which style (in-dash cd, or cassette), base radio, medium (Phillips) or premium (HK). I have an '04 with the base system, and the volume control know is wacky; sometimes turning it has no effect, sometimes it does what you want it (rarely) sometimes it does the opposite of what you want it to do. Fortunately, the volume control on the steering wheel works fine, so it's not really an issue, as that's the one I prefer to use anyway. It does make adjusting bass/treble/fade tricky, though, so I just left them alone once I got them to where I want them most of the time.
Old Mar 6, 2019 | 08:34 PM
mollusc's Avatar
if neither the volume on the unit nor the volume on the steering wheel works but you can still hear something, it seems likely that the issue is with the amplifier, or with the preamplifier in the head unit. i would start by checking for issues with the amp -- under the driver's seat i believe.
Extinct
Nov 5, 2018 11:38 AM
hymlopez
May 1, 2014 12:36 PM
wastesandpines
Feb 16, 2014 08:28 AM
domyo
Aug 27, 2008 06:26 PM
Petes 03 Rig
Jan 5, 2006 08:13 PM
