Radius arm bushings: bolt seized in sleeve
Old May 23, 2010 | 06:57 PM
batiscan's Avatar
Default Radius arm bushings: bolt seized in sleeve
Down to the radius arm bushing now: nuts are very hard to get off and then the bolt is seized in the bushing: since there's not much space to get a good whack at it, does anyone have a good trick other than trying to cut the bolt by getting a cutting disk between bracket and bushing?
Thanks for any hint
Old May 24, 2010 | 06:53 AM
antichrist's Avatar
If you can't drive it out, then it's sawzall time. A cutting wheel will be more likely to cut things you don't want cut.
Old May 24, 2010 | 09:04 PM
batiscan's Avatar
Good. that's something I got. always used it for wood demolition. I'll get some metal cutting blades and give it a try.
Cheers!
Shiftonthefly1
Apr 7, 2015 06:49 AM
AuZZZie
May 21, 2012 03:42 PM
LeakyDisco
Sep 9, 2011 11:16 PM
Disco Mike
May 4, 2011 07:08 PM
Spencerfitch
Jun 26, 2010 05:17 AM
