Range Rover/DII Front Rotors
Old May 27, 2012 | 12:29 AM
cmclaughlin07's Avatar
4wd High
Default Range Rover/DII Front Rotors
Would the front brake rotors from a 99' RR work on a 99' DII? I'm asking because I might be able to work out a sick deal on a set of EBC rotors. I know for a fact the parts numbers are different for the front rotors only (rear rotors and pads are the same numbers), but I didn't know if it was like the 1-301 Mobil1 oil filter situation where a part that "isn't compatible" is actually compatible.
Any thoughts?
Thanks guys.
Old May 30, 2012 | 12:30 PM
4wd High
Alright, first and last bump for good luck. I'm not a gamblin' man and if I don't hear anything from you guys I'll probably pass on the setup.
Old May 30, 2012 | 12:45 PM
tee51397's Avatar
I believe on the fronts the hat offset is different.
Old May 30, 2012 | 03:57 PM
4wd High
Sounds good. Thanks.
bcolins
Sep 14, 2015 01:10 PM
RITTER
Aug 24, 2012 03:16 PM
ewok
Aug 18, 2010 02:03 PM
bowagon1
Apr 22, 2009 07:14 PM
alasko
Jun 16, 2008 10:31 AM
