Range Rover wheels on Discovery 2?????
Old Apr 16, 2013 | 11:45 PM
nz_landy's Avatar
Default Range Rover wheels on Discovery 2?????
I have a 1999 Discovery 2. I have some wheels of a 2003 Range Rover that I want to fit on my Discovery 2. I am having trouble finding some wheel nuts that will fit? Can anyone help me? Thanks
Old Apr 17, 2013 | 04:24 PM
04duxlr's Avatar
I believe the hub is machined slightly larger on the RR wheels also, so the wheel will be supported by the lug nuts only instead of the hub. You might want to look into getting some type of shim to make up the difference or you may get a nice shake.
As for the lugs, I though the D2 ones worked with the RR wheels. Hopefully someone who has done this can answer that.
Old Apr 17, 2013 | 04:49 PM
Those wheels won't work without a hub centric adapter, I think that is what it is call, then you looking at a bunch of money and a wheel that I wouldn't take off road because of the adapter and how it effects the strength of the lug nuts.
Old Apr 17, 2013 | 05:01 PM
ZGPhoto's Avatar
Yeah it's a hub centric adapter you're looking for, and the lug nuts are much different.
honda50r
Sep 24, 2012 10:35 PM
Vincent@CEC
Mar 9, 2011 05:08 PM
Vincent@CEC
Mar 9, 2011 03:15 PM
Vincent@CEC
Member Group And Special Buys
Jan 4, 2011 05:21 PM
2003Disco2
Jul 27, 2006 03:43 PM
