RAVE CD
Old Dec 6, 2007 | 03:03 PM
marcwestbmw's Avatar
Default RAVE CD
I went to green-oval and downloaded the RAVE CD. But, it appears I have the "Range Rover" CD, not the "Freelander/Discovery II" CD. I downloaded again, thinking I picked the wrong file. Both times I ended up with "Range Rover".[:@]
Anyone else have this problem? Am I completely without computer skills? Does anyone have a copy they could burn for me?
Old Dec 6, 2007 | 05:16 PM
Disco2Guy's Avatar
Default RE: RAVE CD
http://green-oval.com/joomla/index.p...&Itemid=29
That is the direct link to the Disco2 & 2001 Freelander RAVE CD. Click it and you should get a prompt to open or save the file. I double checked the link, completed the download and opened the zip file to confirm its contents. If you still have issues, I have a copy on cd (fully extracted) that I can copy and send your way if needed. Good luck.
Old Dec 6, 2007 | 05:32 PM
Default RE: RAVE CD
Thanks Disco2Guy. I'll try downloading again. When I looked at my previous download, it opened with the Freelander/Discovery CD cover. But, all the info was Range Rover.
Old Dec 6, 2007 | 09:25 PM
Camdisco24's Avatar
Default RE: RAVE CD
Rover Renovations will send you it for free if you order it off there website, it has everything and its on a disk so that helps if you need it anywhere else. If you can wait 7-10 days I would try that. If green oval doesn't work R-R is my second recommendation.
Old Dec 7, 2007 | 10:11 AM
Default RE: RAVE CD
OK the information on the disc is for the "New Range Rover, Range Rover, Defender". Is this the indo I need? Is the "New Range Rover" a Disco? I'm still confused.
Old Dec 7, 2007 | 04:32 PM
Camdisco24's Avatar
Default RE: RAVE CD
Hmmm You must have a different version because mine doesnt have any of that it had Disco I disco II and Range Rover. New Range rover is def. not a Disco. Where did you get the disk?
Old Dec 7, 2007 | 04:43 PM
Default RE: RAVE CD
Green-oval download. I even used the link Disco2Guy posted. Same results.
Old Dec 7, 2007 | 04:53 PM
Camdisco24's Avatar
Default RE: RAVE CD
yeah I didnt use them. I got mine sent for free from Rover Rennovations but i checked their website and they arent offering the CD anymore. You may have to check around at some other LR sites, and someone on here might be able to send you the discovery file.
lowill
Feb 3, 2009 11:08 PM
andrewcloy
Sep 12, 2007 11:32 PM
andrewcloy
Sep 12, 2007 12:31 AM
03springer
Aug 23, 2007 04:25 AM
Drnknmnky13
Oct 10, 2006 02:38 AM
