Re-sleeve engine a safe approach??
Old 12-20-2010, 01:12 PM
cobbcj7's Avatar
Question Re-sleeve engine a safe approach??
I have found a guy near me in Charlotte that seems optimistic that he can re-sleeve the bottom part of me 4.6L. It has overheated several times to pretty extreme measures. The gaskets blew, anti-freeze in the oil, and pressurized cooling system indicates a cracked sleeve. Would this be a bad idea to have the guy try and fix it?? Could the block warp or have gone bad?? I have 95,000 miles and he said it should be good to go... Your thoughts please
Old 12-20-2010, 01:26 PM
Long Haul's Avatar
If I was going to get one resleaved I would go with the tophat liners. That way you know for sure youll never have problems with them again.
Old 12-20-2010, 02:37 PM
0304Disco's Avatar
Considering the sleeve might well be the stronger of the two (Block aluminum and sleeve steel) I would say save yourself many head aches and get a replacement engine that has some known good service and was removed from a vehical in good working order.
Old 12-20-2010, 02:43 PM
DiscoIIBrandon's Avatar
Shouldn't you get the block pressure tested before doing anything else with it?
Old 12-20-2010, 03:24 PM
You will just be wasting your money, 4.6's have the thinnest sleeves of all Rover engines and if you have beaten that engine up as much as it sounds like it is a boat anchor.
Last I head, top hats are over $500 a cylinder.
Start over and get another engine.
Old 12-20-2010, 09:15 PM
dynomite's Avatar
D&D fabrications sells the sleeves for $85 a piece. he can talk most any machine shop through the process. his name is mark and his website is www.aluminumv8.com. mark also has some interesting performance kits that many of you might be interested in.
also there is LA Sleeve their website is www.lasleeve.com. they sell em for $95 a piece.
Old 12-20-2010, 10:24 PM
cobbcj7's Avatar
Default This is new info
Apparently the Bosch engine can not be resleaved?? British Atlantic guys told my mechanic buddy that you can only resleave the GEMS engine and not the Bosch.. So my next approach the Insurance wrecked auctions for a totaled truck with good motor...
Does anyone have any intel on not being able to resleave the Bosch 4.6L??
Old 12-21-2010, 08:06 AM
dynomite's Avatar
the intel i know is that i know of a resleeved bosch engine running great.
http://robisonservice.blogspot.com/2...-failures.html
check this out. this guy seems to infer that you can use flanged liners.
i would call the guys at the businesses i listed above
here they are again.
D&D Fabrications www.aluminumv8.com
LA Sleeve www.lasleeve.com
they manufacture the sleeves. i've talked to them both and got good info.
Old 12-21-2010, 10:50 AM
oysterhead's Avatar
call em and let us know what you find out.
Old 11-07-2011, 08:20 PM
JagPres2's Avatar
I am looking into the same situation with my D2, what did you find out and what did you go with?
Quick Reply: Re-sleeve engine a safe approach??
