Reaching the steering box bleeder screw
Per the RAVE, bleeding the PAS it simple enough. However, that steering box sure is down in there. I could remove the intake that connects to the air filter for better clearance, but it says I have to turn on the car to idle it... Not sure I want do that.
Any tricks to reaching that bleed screw on the steering box?
Trying to get a few simple services done today/this weekend.
-Anthony
-Anthony
All that screw really does is primes the pump by allowing air out.
Problem is - it can snap if the sealant came out of the center of it and the
internals rusted.
This screw is the same as on a brake caliper.
Loosen it just a hair until the air can get out of the pump and out of the system then tighten it.
The PS pump will change tone when this happens.
The PS pump - when pumping - will self bleed the rest of the air out itself.
internals rusted.
Now, you tell me. You should have seen the geyser when my daughter was turning lock to lock! LOL
All is good. I tightened it back up and kept an eye on the level in the reservoir and filled as needed. Tested it and the muffled groan or squeak, if you will, when I was turning from center is now gone.
I washed what I could, but drove her to the car wash to rinse everything else off in and under. People were staring when right before the car wash, at a stop light, she was smoking as she burned off whatever spillage I hadn't gotten. Quite a sight.
I guess I got lucky that I didn't f* something up - other than my glasses.
-Anthony
-Anthony
X2 on the geyser, been there while swapping out my P/S fluid this summer while my wife was turning it lock to lock. The rubber cover came apart in crumbs when I removed it, and I need to get a replacement. Any suggestions on what will give the best fit and stay in place??
Boom! Found it... 'should work.
Help/Universal bleeder screw cap (13962) | Brake Bleeder. Universal Type | AutoZone.com
-Anthony
-Anthony
