ready to sell for parts
Old Aug 15, 2015 | 03:15 PM
tintih's Avatar
6th Gear
Default ready to sell for parts
My 99 disco was running fine backed up to leave an eating establishment and it stalled , started up with horrible miss limped home at 30 miles per hour. Changed plugs wires coils maf still getting 1300 304 305 307 codes have checked vacuum leaks driving can only be done if you. Manually shift from low to high cannot go more than 40 am ready to sell for parts I am so frustrated. Any help would be appreciated
Old Aug 17, 2015 | 08:07 PM
Charlie_V's Avatar
I'm not familiar with the codes you list and i'm on my phone so I can't look them up quick but such an abrupt change makes me think it is an electronic issue. The only time my truck did anything similar (work fine, get out, get back in and runs like crap) it was the MAF. Not saying that is but if you know any other Disco owners ask if you can swap them out for a few minutes. I'll look up the codes.
Another idea that's easy to check is the ground strap at the back of the driver side of the engine. That nut can come loose and if the engine isn't properly grounded, crazy stuff like that can happen.
Coils aren't likely. Nor are wires... why would they all go out at once?
Old Aug 17, 2015 | 09:23 PM
R0VERGUY's Avatar
-have you checked your fuel pump to make sure you are getting good pressure? The fact that you stalled out could point to a fuel issue. A pressure test at the schrader valve should tell you if you have a dying pump or if you should look somewhere else.
-Have you checked the misfiring cylinders to see if you are getting any spark at all there?
-I went into the store one time and came out and started the truck only to find a bad misfire. I bought 2 new coils and it solved the problem but you said you've already tried new coils, right?
jhill15
Apr 6, 2019 11:07 AM
adigerol77
Jul 16, 2011 09:11 PM
Spike555
ROAMING WITH FRIENDS
22
May 5, 2010 10:37 AM
skatelove303
Jul 21, 2009 01:59 AM
trademaninchina
Jan 10, 2008 02:56 AM
