Really bumpy ride
Old Oct 16, 2019 | 10:35 PM
landroverdude's Avatar
Default Really bumpy ride
Hey guys does anyone have an idea as to why it's so bumpy like I feel every small hole on the road and off-road big bumps slam the back of the car and I always hear a bang or big clunk, I just like 3 weeks ago got new springs and shocks and have replaced steering rod and drag link, any idea as to what else might need to be done?
Old Oct 16, 2019 | 10:58 PM
Dave03S's Avatar
What springs? What shocks? New Steering Damper too? How much extra weight on/in your truck? What Tires? What air pressure?
Might be able to make a more educated guess with more info.
Old Oct 17, 2019 | 05:53 AM
Jason Feuerstein's Avatar
As an initial matter, it's a solid axle truck. If you're used to the ride of a vehicle with independent suspension, it's going to feel rougher because any shock to one side will travel to the other side.
The suspension on these vehicles are simple. If it's still too rough, you've either put too stiff parts on and they're not damping properly, or you've put too soft parts on and you're running out of suspension travel. As noted, more detail on your vehicle would help.
Old Oct 17, 2019 | 07:50 AM
wjsj69's Avatar
Clunking for me was worn out sway bar links.
Old Oct 17, 2019 | 08:42 AM
mollusc's Avatar
watts linkage, sway bar linkages, any of the suspension bushings... there are so many things it could be.
or since you just went through and replaced a bunch of stuff, maybe something was installed incorrectly.
Old Oct 17, 2019 | 12:27 PM
It has bilstein 4600 gas shocks and terrafirma medium duty springs that gave it a slight lift also new steering damper also bilstein, no extra weight. Heavy duty driveshafts if that counts as extra weight.
Old Oct 17, 2019 | 01:32 PM
Richard Gallant's Avatar
Tire pressure too
Old Oct 17, 2019 | 02:10 PM
Do you have any other modifications to the car, e.g. steel bumpers? Medium duty springs are going to be too stiff for an unmodified vehicle.
Old Oct 17, 2019 | 02:43 PM
@Jason Feuerstein I have to disagree I have terra firma MD springs and OME shocks all round and my disco rides nice empty and full
Old Oct 17, 2019 | 02:49 PM
Dave03S's Avatar
I have had the Bilsteins before, I recall they were quite firm. Still I agree tire pressure and load rating will contribute.
