Is it really OK to jack on the oil sump?
Old Jan 23, 2022 | 09:31 AM
Brandon318's Avatar
Default Is it really OK to jack on the oil sump?
I’m thinking about replacing the motor mounts while I have everything easily accessible during my HG job I’m currently in the middle of. RAVE says jacking on the oil sump is the appropriate way to support the engine while replacing the mounts, but all my experience working on cars tells me cast aluminum sumps and jacking on them is a recipe for disaster.
Old Jan 23, 2022 | 09:48 AM
Best4x4's Avatar
I've done it on a LR with a block of wood between the sump and the jack.
Old Jan 23, 2022 | 09:53 AM
tnrangerover's Avatar
Use a wide block of wood between the jacks and sump. Have at it.
Old Jan 23, 2022 | 09:57 AM
The Deputy's Avatar
It's fine, as mentioned, block of wood and jack it up.
Old Jan 23, 2022 | 10:22 AM
Brandon318's Avatar
I guess since it's just the block, there's that much less weight than before when the heads and intake manifold were also on there.
Old Jan 23, 2022 | 11:40 AM
mln01's Avatar
Doesn't matter, but that too. I did it with the engine fully assembled and installed. No problem.
Old Jan 23, 2022 | 01:18 PM
keninnc's Avatar
Remember the transmission. It's been awhile since I did my swap but I think I remember their is a support under the transmission. You will be raising the transmission with the engine. You can use 2 jacks, one to support the transmission to offset some of the load if you are concerned with jacking under the engine's sump.
Old Jan 23, 2022 | 02:16 PM
Richard Gallant's Avatar
That sump is really thick it is not a cheap thin piece. Just make sure the wood goes from side to side.
Old Jan 24, 2022 | 03:22 PM
Motorhead1's Avatar
Block of wood and a bottle jack. I like to unbolt the upper fan shroud, that way the fan can move freely up. I usually pay close attention to the large electrical wiring loom running along the fire wall, the intake manifold will squeeze it. Just did this job last weekend.
Old Jan 24, 2022 | 03:52 PM
Brandon318's Avatar
Thankfully I'm choosing to do this in the middle of a head gasket replacement. Literally nothing is attached to the engine right now.
