Rear axle seal (o ring) leaking? Contaminated brake pads
Old Jan 7, 2020 | 03:51 AM
neuropathy's Avatar
Default Rear axle seal (o ring) leaking? Contaminated brake pads
Hi everyone, I've found that there's differential gear oil contaminating the brake pads on one side of my D2. I ordered an o-ring from Atlantic British - Item:FTC4919 - which I believe is the right part, corresponding to part 2 in the diagram below. I'm not sure this is what's causing the leak, but I thought I'd check here to see if this is a very common issue and would most likely be the source of the problem. I bought brake pads as well that I'll use to replace the contaminated ones after resolving this issue. There was a time when the vehicle swung a bit on the highway when I needed to brake a bit more urgently than usual. I cleaned things up and that's helped a lot.
I've also planned to refill the differential after draining it as soon as I've done the rest of the work here. I should be able to replace the o-ring without draining the differential though, right? I'm also wondering what gear oil others here would recommend using.
I appreciate any input.
https://www.roverparts.com/Parts/FTC4919
Old Jan 7, 2020 | 05:18 AM
SundayFunday's Avatar
I had a period of time where I was having trouble getting that seal to seat properly; ( I had some burrs from cleaning corrosion on the sealed wheel bearing unit which I couldn’t seem to get right the first time. Or the second time) so I had replaced it about 3 or 4 times in a very short time -
so if you haven’t flushed your diff fluid in some time, now is a great opportunity to flush & replace.
That said, once I’m disassembled to the wheel bearing, i can say that I’ve raised the jack to pitch the axle & have virtually no loss of oil while replacing that seal.
I flush my dif fluid more frequently then most would, therefore I just use a Napa brand or valvoline brand synthetic 90/110 weight gear oil
Old Jan 9, 2020 | 02:31 AM
neuropathy's Avatar
Thanks pal, I’ll have to tear things down at some point and get in there. Did you use anything to help seal the o-ring?
Old Jan 9, 2020 | 06:38 AM
Sixpack577's Avatar
Put a thin film of oil or vaseline on the o-ring to prevent knicks or tears during installation/assembly.
Old Jan 9, 2020 | 09:22 PM
Jwehking's Avatar
I had same problem. Replaced the o-ring as suggested here but almost ruined my new brake pads as it was a leaky bearing. Unless that ring tears, I don’t see how that fixes anyone’s problem.
Old Jan 9, 2020 | 11:53 PM
neuropathy's Avatar
Ah I see - I'll have to prepare for the same, then, seeing as we have the same exact vehicle. How did you resolve the leaking bearing issue?
Old Jan 10, 2020 | 06:18 AM
The O ring is the only barrier back there to leak fluid I believe.
the wheel bearing is a sealed unit. It doesn’t contain fluid to leak - nor is the construction of a sealed bearing able to allow passing of fluid.
I mean- your bearing would have to be so destroyed that it would be obvious that a weeping gasket is not the issue to address..
when you remove the rear wheel bearing to get to gasket- you can confirm this by spinning the bearing. It should be silky smooth. If there is play / then replace the unit.
get a cpl o rings, they’re cheap. You shouldn’t have any problems changing it.
Old Jan 10, 2020 | 01:52 PM
neuropathy's Avatar
Thanks - I only detected leakage on the left side, but it would make sense to reseal both sides or all four when doing a brake pad replacement at this point. I’ll probably deal with draining and refilling the differentials as well.
Old Jan 10, 2020 | 02:27 PM
front axle seals are altogether different.
Your rover should provide you with plenty to service - no need to get into anything unnecessarily.
Old Jan 10, 2020 | 02:31 PM
neuropathy's Avatar
I see. I was going on the suggestion to get a couple of o rings - so I'll just deal with the one where I found the contaminated brake pads and maybe do a flush and refill on the rear differential. I think there's a way to check the fluid level, which I'll have to look into. Thanks again!
