Rear axle seal (o ring) leaking? Contaminated brake pads
Old Jan 10, 2020 | 11:23 PM
Jwehking's Avatar
The bearing is a hub assembly. I read all the suggestions saying it can’t be the bearing cause it’s sealed. Anyway, bought a hub on eBay (included wheel sensor) and problem solved after messing with the o-ring several times. The seal must leak and axle lube comes thru the bearing. When I looked closely at the fresh lube leak I could see it was coming from the bearing and not the o-ring. Not saying it’s your problem but it’s something to consider. Good luck
Old Jan 13, 2020 | 12:36 AM
neuropathy's Avatar
Thank you - I'll definitely keep it in mind. I'll begin just by replacing the o-ring and seeing if I just wasted money on brake pads. Crossing my fingers here.
clint70
Jun 26, 2016 09:15 PM
tsuami1
Aug 29, 2014 08:59 AM
lowerrb
Mar 30, 2009 06:58 PM
navysar
Dec 24, 2008 07:08 PM
RamblingMan
Sep 16, 2007 05:54 PM
