Rear coil conversion = Battery draw?
Old Nov 8, 2008 | 07:25 PM
leeoaks's Avatar
4th Gear
Default Rear coil conversion = Battery draw?
Recently changed out the rear air bags to coils and had the sls lightwas remidiedby the installer. My problem:when car is off, still hear the pump(under drivers side) making a noise every 20-30 seconds like it is checking itself. The pump is not coming on/running, but seems to constantly checking for the bags. I pulled the cover off and you can hear the pump making a constant low noise and if you put a hand to it, you can feel a constant vibration. If the truck sits for more than two days it wont turn over, already put in a brand new battery (got to love that Sears Die Hard battery warranty) and still after two days of sitting it goes dead. Is there another alternative to shut the whole system off, or shouldI just disconect the pump altogher to eliminate the battery draw? Thanks in advance on any replies.
Old Nov 8, 2008 | 07:37 PM
Default RE: Rear coil conversion = Battery draw?
I have heard of this happening before, there is a way to turn off the pump, I think the ECU needs to be programmed to not run the air compressor.
Otherwise I think that you can just unplug it.
Old Nov 9, 2008 | 07:55 AM
Lee,
You will need to have a mechanic scan and shut down the SLS system to stop this problem.
PM me with your tele number, I am looking for a used SLS pump and may the height switches.
Mike
Old Nov 9, 2008 | 02:07 PM
leeoaks's Avatar
4th Gear
Tried to disconect the pump, solved the battery draw issue but created a new one... The SLS light came on and as soon as I hit 20mph the suspension chime came on and does not go off till back under 20 mph.
Mike- the shop that did the install was able to get the sls light to go off, is that different than shutting the system down altogether?
Old Nov 9, 2008 | 08:04 PM
Darover's Avatar
Go to the dealer to get the slabs ecu reprogrammed before you go nuts. Had the same chime thing over 20mph and that ride to the dealer was the longest one ever. Blast the music and go!!!
Old Nov 10, 2008 | 07:46 AM
ORIGINAL: leeoaks
Lee,
Good talking with you.
Yes, if the chimeys are still ringing then you need to shut the SLS function down in the ECU.
Take care
Tayrover
Sep 23, 2011 02:16 PM
jasonrusso
Jul 14, 2011 08:27 PM
b_woodroaster
Nov 5, 2010 08:54 AM
Spensive
Mar 19, 2010 06:36 AM
jycsalas
Dec 6, 2009 06:45 AM
