Rear door adjustment?!?!
Old May 4, 2011 | 04:51 PM
IDAHO's Avatar
Default Rear door adjustment?!?!
So I drove around for a while with my rear door fully open (don't ask...) and now it's hanging low...in other words, when I try to close it I have to lift the door to get it to line up. Is there a known method for adjusting the hinges? I noticed two round plastic covers in the door by the hinges and they reveal a small bolt head. Is this an adjusting bolt?
I already tried loosening the hinge bolts and shifting it around a bit, but as with other shtuff I try it did not end well. Let me know if you are a door guru....I'm also having trouble with the lock sticking, but I'm pretty sure that's associated with the door being out of whack.
I'm sure it's also completely possible that I have completely bent the hinges....
good times!
Old May 4, 2011 | 04:53 PM
IDAHO's Avatar
Oh....it's an 01 discoII....
Old May 4, 2011 | 05:41 PM
jafir's Avatar
Do you have the RAVE manual? If not, download it from www.landroverresource.com
It has a section on removal and refitting the tail door, with a blurb about adjusting it. It basically say don't tighten the hinges all the way, move it around until it's right, and then tighten them down. There are drawings too.
Old May 4, 2011 | 06:10 PM
IDAHO's Avatar
Yea, I have it....I didn't think it would have anything but removal...sweet!! Thanks.
Broken08
Apr 3, 2022 10:27 AM
coldstart
May 26, 2021 01:34 PM
mrobey
Jan 25, 2012 12:37 PM
ljdiscovery
Nov 23, 2009 04:05 PM
delboy
Dec 11, 2005 04:50 PM
