rear door stuck
Old May 24, 2010 | 08:26 PM
4ruf's Avatar
Default rear door stuck
I have a 2004 discovery, and I can not open the rear door.
I am so mad I feel like blowing the door off its hinges.
Help please.
Old May 24, 2010 | 09:26 PM
Pop the Land Rover emblem off of the rear door handle with a screw driver.
Spray the handle with silicone spray.
Work the handle.
Spray again.
The door will open.
This is common on ALL trucks with this type of cargo door and the handle, hinges and door slide need to be lubed at least every 6 months.
More often if you live on a dirt road or in the winter time if they use road salt.
It is recommended that you lube ALL hinges on your cars every 6 months.
Silicone spray will not attract dirt like WD-40 will for example.
Old May 25, 2010 | 07:55 AM
hilltoppersx's Avatar
it may take a good 5 mins of working the handle and spraying silicone in there.
Old May 25, 2010 | 07:27 PM
4ruf's Avatar
Thank you guys, I will give it a shot when I get home.
Old Oct 3, 2013 | 07:19 AM
TRIARII's Avatar
Default My door wont close! Anobody care to shed some light for me?
Found this is the search section so Im reviving the thread. My cargo door was left open and now the door hand itself is compressed in and does not move. Door does not shut or secure either when I attempt to close the cargo door. I will remove emblem and use penetrating oil, but Im not convinced that will resolve the problem here. Seems most people are having problems with the interior components of the cargo door, I think mine is the handle itself. Worst case scenario Ill replace handle with new one but I need a temp solution. Any help would be appreciated.
Old Sep 28, 2015 | 09:10 PM
MPDano's Avatar
Did you ever get this resolved? Mine is doing the same thing. Won't open from outside or inside cargo door handles.
Old Sep 28, 2015 | 09:33 PM
MPDano's Avatar
Ok, got it. Here are some clearer instructions:
1) Use a butter knife to remove the oval logo off the black cover covering your cargo door handle.
2) Spray silicone spray on all the moving parts inside hole.
3) Work the handle till it comes free.
4) Spray some silicone on the oval logo tabs so it snaps in easier.
5) Wipe off excess silicone spray that now is dripping down behind your license plate
Old Sep 28, 2015 | 11:51 PM
cappedup's Avatar
Mine does the same. I have a routine of climbing in the back, pulling off the inner door card, and opening it that way. Then spray everything. Then curse after another 4-5 months.
Will try the less stressful 'butter knife' trick.
Old Sep 29, 2015 | 12:06 AM
toofaroffroad's Avatar
Hi guys, mine does this occasionally to. I just knock the door handle from the outside with a hammer or anything hard and it works again. Stick, shoe, her bottle etc etc. works every time for me.
Old Sep 29, 2015 | 12:52 AM
jimvw57's Avatar
Mine only gets stuck after I put something big enough in there that I can't get out the side doors. A shot of penetrating fluid, wait 15 min and it opens right up. I tried using some motorcycle chain lubricant this time to see if it lasts longer... time will tell.
