Rear Door Subwoofer Bad Sound
Old Aug 17, 2009 | 02:40 PM
ColoDisco's Avatar
I have JL's in my Audi 4kQ. They sound amazing.
Old Aug 17, 2009 | 04:58 PM
98roverguy's Avatar
These look like a decent replacement. http://www.lanzar.com/itempage.asp?model=MAXP64
I've never been a Lanzar fan but at least they are the correct fit/size and are dual voice coil. I'm not looking to win a sound off, I just want my base back. I could only find one review of this speaker off of amazon.com. 4/5 stars. If I purchase these I will follow up with a review and let you guys know.
Old Aug 17, 2009 | 08:34 PM
JBEGIN's Avatar
Roverguy,
http://www.onlinecarstereo.com/CarAu...roductID=19517
same impedence, same mounting hole pattern...
what size amp. do you have?
Old Aug 17, 2009 | 09:01 PM
ljdiscovery's Avatar
I had the same thing happen in my DI. I bought two JL Audio W0 subs and was going to add a nice amp to drive them. AFter realizing that I might have wire issues, I found a set of subs out of a newer DII. Bought them for $20 installed them and they sound great. Still have the JLs in the boxes, haven't figured out where to put them......PHil
Old Aug 17, 2009 | 09:20 PM
98roverguy's Avatar
See I have the stock amp. Each speaker has 4 wires going to it and from what I understand that means these stock speakers are dual voice coil. If you look closely at the Lanzars I have shown they also have 4 connections (dual voice coil).
Single voice coil speakers only have two wires going to them. I'm worried if I get a set of single coil speakers (like those kickers) I may lose base. I have no idea. Not to mention I wouln't know how to wire it. Does that make any sense?
Old Aug 17, 2009 | 09:33 PM
98roverguy's Avatar
Is the stock amp a 2 channel or 4 channel amp?
Old Aug 18, 2009 | 09:33 AM
JBEGIN's Avatar
idk, i dont have a stock system, couldnt tell u... does it say on the amp. anywere...?
and you wont lose bass with those kickers, they would certainly handle the full out put of the amp, theyre rated for 300 watts each... unless your amp.is a 1000 watt i doubt that youll lose bass. if anything, should get more bass and then u just tune your amplifier to the subs.
Old Sep 14, 2009 | 01:42 PM
Aj6543's Avatar
Anyone end up replacing their woofers with non-oem woofers? 98Roverguy?
Old Sep 14, 2009 | 01:58 PM
SDinDS's Avatar
Cheap and easy fix that I posted back in April:
https://landroverforums.com/forum/sh...ad.php?t=21198
Eric
Old Sep 14, 2009 | 03:03 PM
hilltoppersx's Avatar
i put Audiobahn 6.5" as my replacements. i had to cut away some of the gate for the magnet to fit but they sound AWESOME!
