Rear Door Subwoofers Help
Old Feb 17, 2009 | 04:45 PM
dcreekmore44's Avatar
Default Rear Door Subwoofers Help
I have a 2000 disco II and the two rear door subwoofers are shot. I know this topic has been mildly discussed, but I have not been able to find clear answers on what and if they can be replaced with aftermarket subwoofers. I would like to simply pull out the old speakers, repalce them with aftermarket and install them exactly like the factory subs were installed. Is this possible? Does anyone know the specifications on the subwoofers? (OHM, Watts, anything else?) I pulled out the factory subs, but there is not anything written on them. If it matters? I have the orginal factory harmon kardon system in my vehicle. Any input is appreciated. Thanks in advance.
Old Feb 17, 2009 | 04:52 PM
grussell's Avatar
I believe they are 6.5" and are 4 ohm. Measure the depth of your factory subs and then shop. If you keep the factory system I wouldn't spend a lot on new woofers.
Old Feb 17, 2009 | 05:04 PM
Rover Chris's Avatar
I would go with any subs that are rated at 50 - 100 watts rms
bcolins
Dec 24, 2018 07:35 PM
BUCKLEY
Jun 17, 2013 03:29 PM
Aj6543
Sep 19, 2009 11:07 PM
SpeedAgent
Jul 2, 2007 10:28 AM
andrewkim06
Audio/Visual Electronics
Mar 8, 2007 09:19 PM
