Rear Door washer check valve?
Old Feb 7, 2018 | 08:58 PM
Fallstaff's Avatar
Default Rear Door washer check valve?
Anyone know the part number or where to get the check valve for the rear window washer line?
It seems to go from 3/16 to 1/4 (or it's metric equivalent).
Mine's buggered (and blew out the line at the hinge — now has a big brass joiner in there).
Thanks!
Old Feb 11, 2018 | 01:22 AM
Fallstaff's Avatar
This little guy. Anyone?
Old Feb 11, 2018 | 03:16 PM
number9's Avatar
You'll find it doing a ww web search.
Old Feb 11, 2018 | 04:29 PM
Fallstaff's Avatar
Actually no. I’ve found all the other check valves in the system. The only place I’ve even seen one is in a rovers north kit that has the whole rear assembly.
Its the different size ends that make it unusual.
Old Feb 12, 2018 | 05:29 PM
Fallstaff's Avatar
My faith is shaken. This forum has never failed me before.
Old Feb 12, 2018 | 06:38 PM
Sixpack577's Avatar
I've been searching for the 90 degree elbow that connects the main fuel hose to the fuel rail on the intake.
Nobody knows, none of the LR vendors have them, and they're not on any LR parts diagrams I've found.
Mine disintegrated when I grabbed it to remove it(squeeze tabs on each side and it slides off the rail).
As much as everything else breaks on these trucks, and they're old, cooked, brittle plastic, I can't belive it's not a common replacement part...much like the fitting you're looking for. I feel your pain.
Old Feb 13, 2018 | 09:23 AM
OffroadFrance's Avatar
I hate to see a man cry, so here ya go! Ya gotta learn to be patient
https://www.brit-car.co.uk/product.p...ange_rover_p38
Old Feb 13, 2018 | 09:31 AM
Take a look through these, maybe it's here!
https://www.google.fr/search?q=Disco...-5xDDh2kgtdnM:
Old Feb 13, 2018 | 10:02 AM
Sixpack577's Avatar
Thank you sir...but it's not there either.
Old Feb 13, 2018 | 11:42 PM
Fallstaff's Avatar
Thanks OffroadFrance. Always appreciate your 2¢, but... that's the main one that goes in a few other places (anywhere it's just normal gauge wiper hose to hose). The rear one is odd man out — the output is smaller than the input by quite a bit, just to be difficult.
