Rear Hubs
Old Jun 2, 2014 | 08:32 AM
shanechevelle's Avatar
Default Rear Hubs
Anyone have experience with the rear hubs?
I looked through the rave, the process seems pretty easy. is it really?
There are no "c" clips or anything in the pumpkin that have to be unhooked?
Anyone have a good source of parts?
Price?
Old Jun 2, 2014 | 09:50 AM
ralphobell's Avatar
I hope you have some good air tools available. Removing the stake nut and torquing can be quite a chore to 360lbs. So you will need a torque wrench that will measure to 400lbs. Also a good gear puller or press is needed.
I replaced my right rear hub about a year ago.
Old Jun 2, 2014 | 10:43 AM
dusty1's Avatar
I do not use impact for them. that is for Ralph and sissies
pop center cap from road wheel. use 1 1/4" (fits best) socket and breaker bar to break loose the stake nut (you can use a cheater bar, if you are a women). the rest is a cinch.
there is also a dimpled flare that recesses into the spline on those nuts. I use a little nail set to pop it up.
Old Jun 2, 2014 | 10:45 AM
ZGPhoto's Avatar
32mm works just fine Dusty! Use no more than an 8" breaker bar to ensure manliness.
Old Jun 2, 2014 | 10:52 AM
dusty1's Avatar
until Ralph uses a 32 with an impact and smooths the nut, then 1 1/4 fits best
Old Jun 2, 2014 | 11:00 AM
360lbs, not a problem, I got a 1 inch air gun.
where to buy the part?
Old Jun 2, 2014 | 11:27 AM
ralphobell's Avatar
So I guess all the guys in the shop at Rovers North and Lucky 8 are sissies? Good to know I'm in good company. I'm pushing 50 and have learned that air is a good thing and I will use it any chance I get.
Old Jun 2, 2014 | 12:09 PM
LOL,
no sissies, smarter
04duxlr's Avatar
Not totally a cinch. You need to make sure you get the correct product to seal the hub to the axle splines. I posted about it: https://landroverforums.com/forum/di...splines-63707/. When you put it all back together, you can use your breaker bar and your body as a torque wrench. 360 ft.-lbs. is 360 pounds 1 ft. from the nut so just figure out where you need stand on the bar based on how much you weigh.
Old Jun 2, 2014 | 12:22 PM
dusty1's Avatar
yep....sissies!
they prolly get manicures and wear velvet work gloves, too.
