Rear License Plate Bracket / Barn Door panel removal
Old Sep 20, 2011 | 07:48 AM
sdeleve's Avatar
4th Gear
Default Rear License Plate Bracket / Barn Door panel removal
Hi All!!
I need to replace my rear license plate bracket but the screws are rusted, stripped etc. So I need to gain access through the barn door panel, I'm thinking through the rear speaker chamber?? Does that sound right, I'm trying to avoid removing the entire barn door panel if possible.
I have a new bracket being delivered tomorrow from AB but it won't do me any good until I can remove this busted bracket.
Any insight or suggestions would be appreciated.
Thanks -
Old Sep 20, 2011 | 11:20 AM
Pacerlive's Avatar
Originally Posted by sdeleve
Hi All!!
Thanks -
Have you tried a screw extractor yet.
Old Sep 20, 2011 | 08:23 PM
ajmille's Avatar
take a dremel w a cutting wheel, and cut a straight line through the top with out going all the way through, then use a flat head screw driver to remove, or drill the screw out and retap, also easy outs work.
Old Sep 24, 2011 | 07:59 AM
RAYMAN975's Avatar
one of my rear plate screws are rusted and stripped also. the threaded part where the screw threads into just spins, next time ill use stainless
Old Aug 23, 2013 | 10:03 AM
dlewis812's Avatar
Default but if did need to remove panel
drilling out existing screws obviously a solution. however if did want to gain access from inside what/how would be best way to remove panel?
Old Aug 23, 2013 | 10:18 AM
Drill the old screws out and install new holders.
FrontRanger
Dec 19, 2014 09:39 PM
RWM3
Jan 11, 2010 01:24 PM
thehulk
Oct 18, 2008 07:26 PM
underpsi
Jan 15, 2007 01:20 AM
KWAYZ
Dec 7, 2006 09:09 PM
