Rear Molding
There are 3 plastic clips (short hollow arrow shaped) on the bumper end caps that pop into plastic moulded mounts on the body. You simply and gently pop it off with a flat screwdriver or a trim removal tool. You have to be gentle and go slow so as to not break the plastic clips..... slowly push on side of the L ... then the other side of the L ... back and forth until the whole bumper end cap comes off.
fortunately, the factory rear bumper is easy to remove and reinstall.
