Rear subs
on
Ever since my I owned my disco the rear subs have been blown. They are 6.5". I've found some replacements (upgrade) to the factory speakers. I removed the factory speakers and see thier are four wires attached to each speaker. The ones I'd like to replace them with (a couple of sub Kickers) only have two connections - positve and negative. Does anyone know how I could connect the new speakers? The foam lining around the speakers is completly seperated (blown). Has anyone had any expeience with this?
Looking at the RAVE manual it appears the your 98, which I'm assuming has the premium radio system being an LSE, has dual coil subwoofers. In order to hook up to the subs you bought which are single coil you'll just need to use one of the positive and negative sets for each sub.
Let me know how the Kickers fit in the factory enclosure and how they sound. I want to upgrade mine at some point.
Are you sure it's the subs making the BVVV BVVV noise. From what I have seen it is most likely the rear lisence plate is loose, rear lisence plate bolts are too long or the rear lisence place plastic bracket is brocken. All of these could cause the BVVV-BVVV noise and not the sub.
I hope this helps
I hope this helps
98 rover guy, you are talking about the impedance of the subs, 4 wires= Dual Voice Coil
2 wires= Single Voice Coil there are many options for wiring so you dont over (or under) load the amp. you should be able to just wire one set of leads (+ and -) from each DVC sub to the new SVC subs and just tape off the 2 unused sets really good. The amp will only send power where it is being used.
