Rear Sunroof Rattling
The rear sunroof of my 98 Disco I has rattled ever since I purchased it. Today, I finally went back and found the cause. The passenger side is fine; however, the driver's side is the source of the rattle. There is a rubber (I think) "spacer" missing from the piece of the assembly that follows a track allowing the sunroof to slide open. Sorry for likely not using proper termanology there but that's part of the problem. Does anyone know what that part is called so I can look for a replacement. Also, if there's an easier way than purchasing parts I am open to suggestions.
Thanks... Todd
Thanks... Todd
go here:
Çàï÷àñòè äëÿ Land Rover
click on "in english" and then microcat. You can find a break down of the sun roof parts under body and chassis. maybe you can find the part that way. (I have to use internet explorer to get it to work.. )
Seriously...that web site is much easier.
