Rear suspension possesed
Old Jan 20, 2008 | 01:51 PM
beachpugx1's Avatar
7th Gear
Default Rear suspension possesed
I have an '00 Disc. The back end will go up to regular height and the 3rd off road height. However, it usually rides at the lowest loading heght and is very bouncy. There seems to be no rhyme or reason to when it goes all the way down but is usually within a few miles of startup. Sometimes it will raise on it's own when it starts up but those times it goes down as soon as it gets to the top. The rear step drags over things at times when it's all the way down and is rusted off where the hose attaches to it. Could the problem be as simple as air leaking from the step?
[IMG]local://upfiles/7439/61B6B675D4A946E2BB9F61FCD8280F18.jpg[/IMG]
[IMG]local://upfiles/7439/75D76940BA7D46CBA0C069C1628AD68B.jpg[/IMG]
Old Jan 20, 2008 | 03:07 PM
Default RE: Rear suspension possesed
What year and model are you talking about??
You really need to address that rust.
Old Jan 20, 2008 | 04:29 PM
Your air ride is bad. Very common problem on D2's.
Old Jan 20, 2008 | 05:06 PM
First, it is not a common problem, as you make it sound, second, I can't even figure out what he has taken a picture of.
Old Jan 20, 2008 | 05:14 PM
He took a pic of the rear step.
Old Jan 20, 2008 | 06:31 PM
ORIGINAL: beachpugx1
Quit driving it before you cost your self even more money. How mechanical are you?
Old Jan 21, 2008 | 08:07 PM
EVN137's Avatar
beachpugx1
The rear step is all mechanical. The picture shows the shock ( rusted off the step arm ) that raises the rear step to its upper position.
No relation between the two. Had mine replaced ( rusted rear step ) already.
Ed
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
fastrx7man
Jan 28, 2012 12:49 PM
Spike555
ROAMING WITH FRIENDS
Jul 10, 2010 09:01 PM
Kennydhl
Apr 18, 2005 10:54 PM
