Rear Suspension Question
Old Dec 3, 2006 | 01:45 AM
dbwarren's Avatar
8th Gear
Default Rear Suspension Question
My 99 Disco II is having rear suspension issues. If it is parked for 3 or so hours the rear suspension lowers down to the tires. Once the vehicle is started it returns to normal in about 10 seconds. I just bought this so I don't know if this is normal??? Help Please!!
Old Dec 3, 2006 | 09:43 AM
Different Drummer's Avatar
Default RE: Rear Suspension Question
Based on similar issues I had with my Lincoln, you probably have a leak either in one or both air springs in your air suspension. It also could be a stuck solenoid slowly letting air out. When you're driving you don't notice that the compressor is keeping up the pressure, but when you stop, the compressor isn't coming on and the vehicle drops. Keep in mind that I've never worked on this problem in a Rover, but in my Lincoln I sprayed soapy water on the suspension parts and easily found the leak that way. I used http://strutmasters.com for my replacement parts. They make Rover air suspension parts as well and I can definitely recommend them.
TRIARII
Jun 30, 2022 09:48 AM
ljdiscovery
Feb 13, 2016 11:21 PM
Aaron Sandland
Feb 12, 2015 09:35 AM
fastrx7man
Jan 28, 2012 12:49 PM
Cyberbaker
May 6, 2010 08:23 PM
