Rear swaybar removal
Old Jul 25, 2008 | 04:48 PM
Disco2Guy's Avatar
Default Rear swaybar removal
Who's removed it from their truck, and what are your feelings on the ride characteristics afterwards? I have about 100 lbs of gear (Tuffy box and equipment) in my cargo area running on RR1-2 (linear) RTE 2" springs and OME shocks.
Old Jul 25, 2008 | 04:59 PM
NiteTrain's Avatar
Default RE: Rear swaybar removal
I removed mine from my Jeep wrangler. I did not notice any difference on the highway.
Old Jul 25, 2008 | 05:16 PM
You will notice a difference, maybe not the one you wanted.
You should disconnect the front also or you will be out of balance.
If you just have to do this, install front and rear disconnects so you run loose and sloppy off road but still have some stability when on the road.
Old Jul 25, 2008 | 05:34 PM
Disco2Guy's Avatar
Who makes rear disconnects, I haven't really seen anyone make them? I'm planning to get Slickrock front disconnects.
Old Jul 25, 2008 | 07:01 PM
NiteTrain's Avatar
no front swaybar = sloppy on the highway. I dunno about LR's but other vehicles are fine with rear out and front in..no balance prob.
Old Jul 25, 2008 | 09:15 PM
I have seen the rear disconnects but I cannot find them now. I assume that your tried AB, RoversNorth, etc.
Old Jul 26, 2008 | 01:58 PM
snorlax's Avatar
UK and Aussie boards seem to have a lot of threads on the subject and more than a few people say they remove one or both. After crushing a couple of the mounts on my sway bars, I removed both from my 95 D1. This link http://www.landroverexchange.com/for...ages/9959.html , and other postings indicated that before 04 disco's didn't have sway bars; so I figure LR engineers thought is was ok (not that technology shouldn't move forward, but my choice was to spend $$ or not). WCB maintains that swaybars should not be removed saying disconnects are the answer http://www.offroadexperience.com/wcb/emu2.htm. If you want to spend the $$ on disconnects you satisfy both sides of the issue. With my swaybars off the ride seems a bit softer on road on and off with my set up (OME HD lift and 265/80/16 super swammpers). Not sure whether the added articulation will snap the brake lines, but I'll learn the hard way as usual. Look forward to learning more about it from experts on this forum.
Old Jul 26, 2008 | 05:39 PM
NiteTrain's Avatar
That is a good point about over extending brake lines. I've only had vehicles with upper/lower control arms and it wasn't a problem, but with radius arms articulation it very well might be.
Old Jul 26, 2008 | 06:50 PM
Disco2Guy's Avatar
This is true. When I was installing the RTE springs I disconnected the rear and had to remove the calipers becasue of the axle articulation against the lines. Might be a good excuse to go ahead and get the stainless extended lines at the same time.
Old Jul 26, 2008 | 09:18 PM
Switzer's Avatar
I removed the rear sway bar and do not notice a difference in the handling. The rear articulation is noticeable. I would only recommend disconnecting the front sway bar when you are off road. JKS-2001 sway bar disconnects can be made to fit the Disco II. www.discoweb.org has instructions on the install. It takes about 5-10 minutes to remove the rear bar. Maybe more if it is really rusted.
Cheers,
Pete
