Rear wheel hub help please!
Old Nov 14, 2010 | 10:37 AM
lsmit605's Avatar
Exclamation Rear wheel hub help please!
Ok, so I have a leaking hub or o-ring and I am trying to replace the oring first to see if this is the couplrit...I hope it is! I have the brake assy out of the way and all 4 bolts removed from the hub...i figured if i just put my slide hammer on the hub and gave it a few wacks it would come off. Not so! it has moved maybe 1/16 off of the mounting surface. Should I be using a puller (like posi-lock or something) to hold the axle in place while removing the hub. And yes I have removed the axle nut. Any help is appreciated!! ~Luke
Old Nov 14, 2010 | 10:45 AM
Go down load a free Rave CD, link found in my signature, and follow the directions.
Old Nov 14, 2010 | 12:22 PM
NiteTrain's Avatar
replacing the O-ring, new gear oil and adding some lucas hub oil fixed my leak
Old Nov 14, 2010 | 01:25 PM
lsmit605's Avatar
Thanks-
Disco Mike, I have a Rave and I have done everything in the "Rear Axle-> Repairs-> Differential-assymbley" section except steps 3,4, and 5 because all i want to do is remove the hub to get the o-ring changed...is it necessary to remove the prop shaft and pinion flange? Shouldn't the hub come right off after the 4 mounting bolts are removed? Mine seems to be really "tight" and I just wanted to make sure I am not missing something or if I should just put some more back into it...again I am trying to use my slide hammer at this point attached to the studs in the hub.
Old Nov 14, 2010 | 02:34 PM
lipadj46's Avatar
Get a big 3 leg puller from harbor freight the hub is more or less pressed into the axle case.
Old Nov 14, 2010 | 04:44 PM
lsmit605's Avatar
Got it, the axle came out with the hub which seems to be fine. i just needed to get to the o-ring. Replaced o ring and still have some clean up work to do as well as replace the pads, everything was wet. I hope this works! Anyone know where to fins the Lucas Hub Oil that was mentioned? I cannot recall seeing it in a parts house
Thanks!
Old Nov 14, 2010 | 05:35 PM
lipadj46's Avatar
lucas sucks ***** I would never add that stuff to something I want to keep, you can try a 1/3 bottle of white shepherds added to a thicker gear oil like rotella 85w-140. It is fine the axe came out.
Racer X
Oct 10, 2016 09:32 AM
marizcal
Apr 10, 2014 09:11 AM
Disco Alan
Mar 27, 2009 07:50 PM
Quiksilver1850
Nov 25, 2008 01:05 PM
01 Discovery
Dec 1, 2006 12:07 AM
