Rear Windows in 97 Disco
RE: Rear Windows in 97 Disco
HELLO !
THIS SEEMS TO BE A COMMON PROBLEM ON THESE VEHICLES.......IT HAPPENED TO MY '98 TOO.
IF THE FRONT WINDOWS WORK FINE .....THE PROBLEM IS USUALLY THE "WINDOW LIFT ECU" WHICH IS HIDDEN BEHIND THE GLOVE BOX....THERE IS A CIRCUIT BOARD INSIDE IT AND IT NEEDS RE-SOLDERING......OR IF THAT SOUNDS TOO INVOLVED- ATLANTIC BRITISH @ 1-800-533-2210 OFFERS A REPAIR KIT FOR THIS......YOU GET A WIRE AND 2 CONNECTORS AND DIRECTIONS AND IN ABOUT HALF AN HOUR WORKING REAR WINDOWS
HOPE THIS HELPS
HOPE THIS HELPS
HEY AGAIN, OF COURSE I'M @ WORK AND THE INSTRUCTIONS ARE @ HOME..........BUT AFTER YOU GET THE GLOVE BOX OUT.....THE ECU IS MOUNTED TO THE RIGHT ( ON THE SIDE PANEL) HAS 2 ELECTRICAL CONNECTORS ON IT.......IT MIGHT EVEN SAY " WINDOW LIFT ECU" ON IT, BUT ITS TOUGH TO READ BECAUSE OF WHERE IT IS, WHEN I GET HOME I'LL TRY TO REMEMBER TO UNEARTH THE DIRECTIONS FROM THE KIT AND BE MORE SPECIFIC FOR YOU.
clockmaker21
01-07-2010 09:20 AM
