Rear Windows in 97 Disco
Old Oct 15, 2008 | 05:04 AM
ajordan_0012000's Avatar
Default Rear Windows in 97 Disco
I let down my rear windows they won't go back up. What should I do to fix the problem?AJ
Old Oct 15, 2008 | 08:29 AM
XCELLER8's Avatar
Default RE: Rear Windows in 97 Disco
HELLO !
THIS SEEMS TO BE A COMMON PROBLEM ON THESE VEHICLES.......IT HAPPENED TO MY '98 TOO.
IF THE FRONT WINDOWS WORK FINE .....THE PROBLEM IS USUALLY THE "WINDOW LIFT ECU" WHICH IS HIDDEN BEHIND THE GLOVE BOX....THERE IS A CIRCUIT BOARD INSIDE IT AND IT NEEDS RE-SOLDERING......OR IF THAT SOUNDS TOO INVOLVED- ATLANTIC BRITISH @ 1-800-533-2210 OFFERS A REPAIR KIT FOR THIS......YOU GET A WIRE AND 2 CONNECTORS AND DIRECTIONS AND IN ABOUT HALF AN HOUR WORKING REAR WINDOWS
HOPE THIS HELPS
Old Oct 15, 2008 | 09:36 AM
Where exactly is the Window Lift ECU located. I took out the glove box. I don't see anything is it close to the firewall?
Old Oct 16, 2008 | 08:46 AM
XCELLER8's Avatar
HEY AGAIN, OF COURSE I'M @ WORK AND THE INSTRUCTIONS ARE @ HOME..........BUT AFTER YOU GET THE GLOVE BOX OUT.....THE ECU IS MOUNTED TO THE RIGHT ( ON THE SIDE PANEL) HAS 2 ELECTRICAL CONNECTORS ON IT.......IT MIGHT EVEN SAY " WINDOW LIFT ECU" ON IT, BUT ITS TOUGH TO READ BECAUSE OF WHERE IT IS, WHEN I GET HOME I'LL TRY TO REMEMBER TO UNEARTH THE DIRECTIONS FROM THE KIT AND BE MORE SPECIFIC FOR YOU.
Old Oct 16, 2008 | 01:18 PM
I have looked for the Window Lift ECU. I can't find it. Is there a diagram showing you exactly where it located. ThanksAJ
kcirtap
Sep 15, 2010 05:55 AM
clockmaker21
Jan 7, 2010 09:20 AM
bhorwhat
Oct 16, 2007 10:14 AM
allstarbiker592
Sep 14, 2006 09:23 PM
95discotn
Oct 13, 2004 09:28 PM
