Rear Windows Not Working, ECU SOLDER?
Old May 21, 2010 | 10:39 PM
Spencerfitch's Avatar
Default Rear Windows Not Working, ECU SOLDER?
So when I bought my truck about 1 month ago the rear windows only went down "after the truck had been running a little while." Suddenly they work no longer. Does this sound like the Window ECU?
Old May 22, 2010 | 08:39 AM
XCELLER8's Avatar
yes !
This is quite a common problem...the fix is to remove the window ecu and locate the problem circuit and resolder it, OR buy the "Window ECU Repair Kit" from Atlantic British, OR PM me with your fax # and I will fax you the directions as well as my own drawing....you are esentially bypassing part of the ecu with a jumper wire. let me know if I can help.
Old May 22, 2010 | 10:53 AM
Thats why I asked I wasn't sure which one it needed, but now I believe they do the same thing?
Old May 22, 2010 | 11:12 AM
XCELLER8's Avatar
Yup......
Old May 22, 2010 | 11:13 AM
The wiring your talking about is the the rear door correct?
I can't get the stupid plug off the ecu..
Once I get it out, how do I tell the bad solder joint and how is it "bad" do i just re solder it?
Old May 22, 2010 | 01:14 PM
XCELLER8's Avatar
Yes, REAR windows are usually the problem with this thing.
The plug does come off a little hard...as I remember there is some sort of a lock tab arrangement there.
Once it's out , the plastic case( cover) will pop off the circuit board.....and normally there is an obviously bad solder point, may even look burnt a little...and a little solder there is normally all that's needed. If you search here a little more there are some pics by others who have done this.
if all else fails, like I said I can fax you a easy diagram on how to bypass this, a couple connectors and about 2' of wire are all you need.
good luck
Old May 22, 2010 | 02:47 PM
well that was easy!!
Thanks! Now I can use my rear windows on the camping trip tomorrow.
Old May 22, 2010 | 03:31 PM
Did you take pictures?
This would have been a great write up.
Old May 22, 2010 | 03:48 PM
Rearden Steel's Avatar
I was thinking the same thing. I have had my Disco less than a week and the right rear window has stopped working!!!!
I guess I did not offer enough prayer to the Disco God's........
Old May 22, 2010 | 04:07 PM
instg8r's Avatar
I for one would have loved to see a write up on that, I need to fix my rear windows as well...
