Rear wiper blade.
Old Aug 11, 2011 | 07:15 PM
photocrimes's Avatar
Default Rear wiper blade.
Anyone else have problems with the Trico 14-D rear wiper blade? I couldn't get it to snap on for anything. I ended up matching the old blade up to it and dremeling the excess plastic off so it would snap on.
Next time I'll just order the factory blade.
Old Aug 11, 2011 | 11:05 PM
yloDiscoII's Avatar
With DII wiper arms you can't buy the over-the-counter replacement blades (Front or Back), that's why many people do the DI wiper arm swap.
Old Aug 12, 2011 | 06:51 AM
Actually Trico does make them aftermarket. I think the fronts are 24-11 and the back is 14-D. The fronts fit perfect, the back would fit perfect if it was shaped right where it snaps in. The excess plastic keeps it from snapping down all the way. If you shape it a little with the dremel it snaps right on. I'll try to post a pick. The fronts are spot on though. Not much cheaper than factory blades though. I heard the rubber in the Trico blades is better though.
Old Aug 12, 2011 | 06:52 AM
Boy I used the word though a lot. Stupid small phone screen...
Old Aug 12, 2011 | 09:00 AM
dcarr1971's Avatar
FWIW, the 14-D worked for me without any issues when I replaced mine last summer.
I finally switched to DI wiper arms in the front...worth every penny to make this change as I was able to do arms and new blades for only ~$10 more than the cost of replacing the D2 blades...
Old Aug 12, 2011 | 09:10 AM
dgi 07's Avatar
where did you get those? neighbourhood friendly Autozone?
Old Aug 12, 2011 | 09:26 AM
dcarr1971's Avatar
The DI arms, or the 14-D?
Advanced Auto had the 14-D in stock.
I got the DI wiper arms from Randy Williams (Rover Bones Home).
Old Aug 12, 2011 | 09:53 AM
dgi 07's Avatar
the trico wipers... thanks
Old Aug 12, 2011 | 10:28 AM
Western auto, which I thinks those are ADTs or something now.
yloDiscoII's Avatar
Very interesting, news to me, and others that say it's factory or bust for replacement wipers. Do they look the same as the factory wipers (with all the aerodynamic stuff on them?)
