Rebuilding brakes master cylinder ?
Old Mar 12, 2025 | 08:01 PM
Externet's Avatar
Question Rebuilding brakes master cylinder ?
Hello... A master cylinder rebuild kit seems it is just these few parts ----> https://www.ebay.com/itm/29421052118...el%3ADiscovery
Is that all ? Can anyone please link a rebuilding video ? Everything I find is for replacing the master cylinder Anyone did it ?
Old Mar 13, 2025 | 10:23 AM
PickleRick's Avatar
Master cylinders, brake cylinders, they all rebuild the same. Clean, hone, reclean, inspect, lube with brake fluids then reassemble.
The only time I've really fooled with rebuilding brake to clutch items was when the original was stupid expensive or a replacement obsolete...like on 67 fj40 rear wheel brake cylinders. Most of the rebuilds I've done were brake calipers and cylinders for old pre 80s Honda motor cycles.
If you tear down to find any pitting, don't bother with ordering rebuild parts.
You will need a brake cylinder hone. I've also done them with sandpaper taped to a dowel, then attached to a drill but the hone works much better.
At the shop we glass bead blaster and ultrasonic cleaner but it's not necessary to make them look brand new for them to work like new, but it does look nice.
whowa004
May 26, 2022 03:39 PM
Reyesahr
Jan 6, 2016 01:49 AM
drdeadchef
Jun 10, 2012 10:10 AM
97_Disco1
Jan 23, 2011 09:29 AM
mburnett
Sep 27, 2009 02:33 PM
