Recent problems with Cam Sensors?
Old Feb 3, 2008 | 02:43 PM
crownaviation's Avatar
Default Recent problems with Cam Sensors?
Hello all! I find myself back in the garage with the warm red cheeks[:@]again.
96 Disco 4.0 GEMS
I just put in a new fuel pump (needed anyway). Fixed a Crank position sensor plug chaffing issue. Installed a new crank position sensor and [&o]still no ignition.
Truck turns over great (new battery etc..) and hits a little on every 3-4th revolution. Fuel PSI great thanks to new pump and ignition is fine too (plugs have spark and are new). In fact, lots of new in the last few months and it is bothersome. Granted the truck not been in this good shape in about 5-6 years, I still like to drive it every once in a while. The last few hundred miles since all the new parts/TLC have cleared the laundry list of codes.
The only thing I can think of is possibly a Cam Position sensor as I did have the front cover off a couple months ago leading to accelerated death.
Anysuggestions without running testbook?
Has anyone else had recent problems with these sensors? (GM and Ford are generating problems around the same model years)
Thanks, going to wash grease mark off my chin now..
[/align]
Old Feb 3, 2008 | 03:10 PM
Default RE: Recent problems with Cam Sensors?
Do you have any codes??
Old Feb 3, 2008 | 04:51 PM
Just checked a day before the starting problem and there were no codes in the last probably 500 miles before the current issue. Have not tried since the problem.
[/align]
mattrickman
Mar 3, 2011 07:33 PM
w0014170
Aug 2, 2010 02:10 PM
Eurotrash
Oct 1, 2009 07:48 PM
Street Wolf
Jul 8, 2009 08:13 PM
angasreid
May 23, 2007 02:56 PM
