Recurring Waterfall Sound
Thanks for your help everyone.
Say, Savannah Buzz - I bought one of those tests from Napa a while back - I'd seen you posting about it a lot. Thing is I couldn't quite figure out how to make it work with my Rover. Just a huge syringe-y thing with a bulb on it and some testing fluid. The exact one is here: NAPA AUTO PARTS
My coolant expansion tank is plastic - and coolant is continuously pumped through there via the neck of the cap while the car is running - are you familiar with this?
That design (with the constant stream of coolant) makes it impossible for me to perform the test without sucking coolant into the tester - thus contaminating the result.
Am I doing something totally wrong? Prolly - please let me know if there's a better way.
And thanks again!
And thanks again!
Look for coolant on the garage floor after it is parked for an hour.
That will tell you you have a leak.
Ok try this.
When your truck is parked say 1/2 hour.
And, you take the cap off of the coolant tank slowly --
then does it blurp blurp and coolant comes BACK into it?
If so - replace the head gaskets.
Ok try this.
