Recurring Waterfall Sound
Old Nov 24, 2012 | 06:48 AM
ebg18t's Avatar
If it was bled properly and the waterfall goes away but returns after driving for a while it sounds like head gasket leaking and gas getting back into the coolant. Definitely do a chemical test!
Old Nov 25, 2012 | 04:21 PM
LottoMan's Avatar
5th Gear
Thanks for your help everyone.
Say, Savannah Buzz - I bought one of those tests from Napa a while back - I'd seen you posting about it a lot. Thing is I couldn't quite figure out how to make it work with my Rover. Just a huge syringe-y thing with a bulb on it and some testing fluid. The exact one is here: NAPA AUTO PARTS
My coolant expansion tank is plastic - and coolant is continuously pumped through there via the neck of the cap while the car is running - are you familiar with this?
That design (with the constant stream of coolant) makes it impossible for me to perform the test without sucking coolant into the tester - thus contaminating the result.
Am I doing something totally wrong? Prolly - please let me know if there's a better way.
And thanks again!
Old Nov 25, 2012 | 06:51 PM
You are supposed to suck up the coolant, that is what you are going to be testing.
The test detects exhaust mixed into the coolant.
Old Nov 26, 2012 | 01:30 AM
jfall's Avatar
Look for coolant on the garage floor after it is parked for an hour.
That will tell you you have a leak.
Ok try this.
When your truck is parked say 1/2 hour.
And, you take the cap off of the coolant tank slowly --
then does it blurp blurp and coolant comes BACK into it?
If so - replace the head gaskets.
Old Nov 26, 2012 | 07:42 AM
drowssap's Avatar
preasure test your system as already suggested
Old Nov 28, 2012 | 03:45 PM
Dan7's Avatar
Will a pressure test ID a head gasket leak?
mrossipir
Jul 4, 2014 10:29 PM
srockrae
Dec 10, 2012 01:08 AM
Ozzy3313
Nov 29, 2012 12:59 PM
Analogkid
Jan 1, 2011 03:21 PM
rod76
Feb 25, 2010 02:10 PM
