Relay numbering ?
Old Jan 16, 2023 | 03:27 PM
Externet's Avatar
Question Relay numbering ?
Good day.
On page 57 of the Electric circuits RAVE, shows a relay R216.
Where in the manuals can I discern which is that relay R216 ?
I see relays numbered R1 to R14 by the engine compartment fuse box undercover, no R216. Somewhere has to refer/translate R216 as R1 to R14, right ?
Old Jan 16, 2023 | 05:33 PM
XRAD's Avatar
type keys "control+f" with RAVE electrical diagrams open and there are 2 hits.... SLS relay (R216) is in the engine compartment fuse block...for SLABS...do you have SLS? as for which one in the fuse block...not sure...looks like #5 from this older D2 diagram...
Old Jan 17, 2023 | 10:20 AM
Externet's Avatar
Thanks. Yes, the vehicle has the self-leveling suspension. That relay R216 does not show to which corresponds at the fuse box. And the graphic of the fuse box as the one you showed mentions only fuses, did not find one with relays, fusible links listing of which is what.
Old Jan 17, 2023 | 06:01 PM
XRAD's Avatar
...thought you wanted relay 216...you want the 30 amp fuse that goes with it? for the SLS air pump?
Page 24 of RAVE electrical...it's 30A FL9 (fusible link 9)...but looks like this system also connects to the BCU, which will probably throw a code if disabled???
What are you trying to do? that would be helpful to know.
eliminate the SLS? you probably need to disable it via nanocom or you get a code.....or just pull the relay, but not the fuse? just guessing because not sure what you are are trying to do.....
WeekendWarriors87
Nov 26, 2020 04:51 PM
Mr. Tick
Aug 4, 2020 04:20 PM
lr4_2012
LR4
Jun 5, 2019 03:13 PM
xathor
Jul 28, 2017 07:40 PM
dobe1canobe
Jan 26, 2015 12:29 PM
