Removable Winch Project
Old 09-29-2017, 09:35 PM
Alex_M's Avatar
Voltage drop for 15 ft of wire wouldn't be much at all. 4/0 should be your minimum anyway. For a 4.5hp (9,000 lb winch) motor at 12v your drawing 248 amps which for copper 4/0 you'd need cable rated at 90*C/194*F according to national electrical code. You'd be maxing out any 4/0.
Frankly I'd bump to a 250 or 350 gauge even running to the front, or atleast put a few inches of 3/0 inline as close to your battery as possible to act as a fusible link.
Old 09-30-2017, 04:03 AM
The Deputy's Avatar
Received 1,189 Likes on 850 Posts
Originally Posted by LR03NJ
Hi Brian,
Its possible and that will be great but you need at least an AWG 4/0 to reach power all the way to the rear winch since there will be voltage drop per feet of cable. I remember when I had to run an inverter to the back, I think the cable alone cost as much as the winch. Wires need to be run under the truck. LOL!
I assume you are going to leave the solenoid pack mounted to the winch, to eliminate running additional cables for motor direction. And that way, you only need a pos and neg cable running to the front or rear...with some sort of quick-connect (possibly like the Boss snowplow units use). Plus, you could always just ground the cable in the rear to the frame (allowing you just to run one cable the entire length of vehicle).
Like anything, always a few options to hammer out. But, I believe you would want to keep the installation as smooth as possible, quick connects and such. Just picture myself in a ditch full of freezing water and snow...trying to hook up some wires and stuff...not pretty. That reminds me...I have to move to hell out of this snow belt area...lol.
Brian.
Old 11-25-2022, 05:57 PM
Roby466's Avatar
Sorry to revive this old thread... it's still very relevant today and looks like a great project.
How did it go after using the winch? I'm considering the same mod or the Terrafirma hidden winch plate but being able to remove and move to the back would be a plus.
What is the hitch receiver you used as a basis for the project? Was it exactly the right width to fit the frame?
CANAMDiscovery
04-05-2013 10:48 AM
gman1001
Defender
04-28-2012 11:46 AM
CoolBreeze
05-12-2010 04:38 PM
lholho
LR2
10-05-2008 02:10 PM
SuperCharged06
Defender
08-24-2007 07:57 PM
Quick Reply: Removable Winch Project
