Removal of alternator bracket
Old Jan 17, 2009 | 02:20 PM
doomed's Avatar
Default Removal of alternator bracket
I have a '99 Discovery II and the tensioner assembly broke off of the alternator bracket - or so I thought. The broken part was actually the section of the alternator bracket that holds the tensioner assembly. I have removed my alternator and loosened all of the bolts that hold the bracket in place but it still isn't budging a bit. What am I missing? I am praying to God that it is not a part of the block. Help!
Old Jan 17, 2009 | 02:58 PM
Default RE: Broken alternator bracket - please don't tell me I need a new engine!
Can you post a picture?
Old Jan 17, 2009 | 03:24 PM
doomed's Avatar
Here is a picture of the bracket and one of the back side of the tensioner with the broken piece of the bracket still attached. Hope they are helpful.
[IMG]local://upfiles/10813/57CE27412B264F9888F7535F3FB3859C.jpg[/IMG]
[IMG]local://upfiles/10813/DC228005BDCF4F0E85C5C7260CBD5ABF.jpg[/IMG]
Old Jan 17, 2009 | 05:07 PM
raid13's Avatar
yea there are four long bolts holing that bracket in place (13mm) and three small bolts (10mm) one for the intake bracket, one for the coolant pipe and one for the oil cooler line.
i do have an extra one, if you are interested.
Old Jan 17, 2009 | 05:21 PM
doomed's Avatar
I see two long bolts that hold the alternator and then three more long ones below those two - I already have them loosened. I see a small one (10mm) below the long bolt that holds the alternator on the driver's side and another small one on the side of the bracket (passenger side) - I also have them loosened. But the bracket is still tight as can be. Why?
You have an extra what - bracket?
Old Jan 17, 2009 | 05:45 PM
jkid's Avatar
I'm pretty sure you arestill missing a bolt on that bracket (kind of in the middle and hard to see). It's been a while since I had it off, but I do remembergetting VERY frustrated not being able to get the bracket off andlooking for that last bolt.
Old Jan 17, 2009 | 05:48 PM
jkid's Avatar
I also dropped 2 bolts and a socket in that corner of the engine bay, never to be found again. That was very wierd because it doesn't look like there are many placesfor it to get lost.
Old Jan 17, 2009 | 08:05 PM
raid13's Avatar
yes extra bracket, let me find it sunday morning at the shop and i will get back to you.
Old Jan 17, 2009 | 10:33 PM
doomed's Avatar
I found that last bolt and have the bracket off. Thank you so much.
If you have that bracket let me know how much you want for it.
Old Jan 19, 2009 | 09:22 AM
raid13's Avatar
Default RE: Removal of alternator bracket
p/m sent
