Removal of head bolts
Old Dec 29, 2014 | 03:09 PM
dusty1's Avatar
twas my fear. I have yanked too many of the aluminum threads from every other hole in the block/heads....didn't want to add those to the bucket.
Old Dec 29, 2014 | 03:31 PM
sdhow's Avatar
Originally Posted by OffroadFrance
Using ARP head bolts for some years on the Vauxhall Caterham, Ford BDA and Pajero heads. The Paj suffers the same issues as the D2 V8 with blown head gaskets albeit an alloy head to iron block but much higher compression ratio, 19.5:1. I would have thought that 'first use' threads could take much more than 90 lb/ft but problem is stretched weakened threads in well used blocks create a different scenario and also embrittlement comes into play. If it were me, I'd go for 3-4 torquing stages on an older block with the thread super lube and after 3 button it up and run the engine up to temp and then a final re-tighten to say 90 lb/ft once cooled down. Alternatively, as Dusty states, let the bolts stretch some overnight and do a final tighten which saves refitting all the rocker covers and intake tat and then stripping it all off again then refitting it all back - tedious or what?
I hate head bolt threaded into alu blocks in any case 'cos they always frick up sooner or later
Source some helicoils or inserts just in case.
OK, guys...I appreciate the guidance, but let's clarify:
I'm using the ARP stud/nut kit, NOT bolts. The reason I'm going to the studs is for just the reason Dusty stated - I don't want to pull the freakin' threads out of the block!
And I have no intention of pulling the upper intake and valve covers again once it's buttoned up to re-torque after heat cycle. That's WHY I'm going away from the factory stretch bolts!
Is 100 ft.lb. excessive with the stud/nut kit, or should I settle for the 88-90 range?
Old Dec 29, 2014 | 04:09 PM
dusty1's Avatar
That is the question.... Most get to 80 and call it good. Arp has had that 100 info up for years. I've only used the studs once. 100 seems excessive and a risk.
Maybe start a new thread to get more opinions.
Old Dec 29, 2014 | 06:10 PM
OffroadFrance's Avatar
Apologies, at cross purposes. I've never used ARP studs and nuts although I'd reckon they'd be a safer bet on the aged threads in alu. Provided the studs are well seated and fixed I would reckon they are an improvement under these circumstances but if it were me I'd coat the shanks heavily with a waterproof/heatproof/hi temp spray paint/laquer to avoid seizure in case later on they have to be removed. (vis Triumph Stag V8 head studs corroded into the alu head). As for torque settings, hmmm, a guess, somewhere around 90-100 lb/ft in 3x stages as the mechanical stress on the alu block threads using studs should be less. IMO opinion I'd be inclined to be guided by the ARP bumph tempered by info from the guys on here that have used the studs in place of bolts as over enthusiasm could be irreversible. There are many guys who have replaced head gaskets on Rover V8's and have far more experience than me on the foibles of the Rover V8 engine. Good luck hope the rebuild goes well.
Old Dec 29, 2014 | 06:11 PM
coors's Avatar
I stopped twerking my stud nuts at 70ft/lbs.
Old Dec 29, 2014 | 08:33 PM
sdhow's Avatar
Will do...I plan to use the ARP Ultra-Torque lube, as they recommend.
Old Dec 29, 2014 | 08:42 PM
dusty1's Avatar
Yes ....do use all the arp recommendations.....exept check out final torque value. 80-90 gets my vote.
Old Dec 30, 2014 | 12:45 PM
sdhow's Avatar
I believe I do agree. 100 ft.lb. seems a bit extreme. After reading the "ARP Studs vs. Stretch Bolts" thread from 1 1/2 yrs. ago, I think I'll stick to the 25-50-75 ft.lb. technique.
Old Dec 30, 2014 | 01:31 PM
dusty1's Avatar
that is a safe #.
some get away with 60. some say 80 is the #. ^ coors went 70.. I would have stopped at 80, but decided to let them sit overnight and hit them with 8 more the next morning (still felt like I was doing a root canal) I have an arp set on my bench, building a new engine. when my heads arrive, I will be stopping at 80. actually I my plan of attack is 20..40.....60..................................... .................80
I think 70-80 is the best/safest clamping zone
Old Jan 3, 2015 | 02:15 PM
sdhow's Avatar
Thanks, Dusty!
Got the bolts out; nearly broke my thumb when one FINALLY let go and smashed my thumb between the cheater pipe and the radiator support! The factory must have these torqued in there at an ungodly high value...or used no anti-seize. Torqued the nuts at 25-50-75...then came back and hit them at 88 ft. lb.
This seemed to work fine.
