Remove Head Bolt Behind Sec. Air Question
Old Dec 30, 2009 | 06:22 PM
humroot's Avatar
Default Remove Head Bolt Behind Sec. Air Question
Hi Guys,
I am replacing my head gaskets and am down to removing the head bolts. I can't seem to get the bolts that are partially blocked by the secondary air valves. I'm thinking I need a swivel extension for the socket, which I don't have. I have a wobble extension but that is not working. Will the swivel extension hold up to the torque? Any other recomendations? Any help is appreciated since I need to get these off tonight and machined tomorrow or I have to wait until next week.
Thanks,
Jamie
Old Dec 30, 2009 | 09:41 PM
meltdowndave's Avatar
Originally Posted by humroot
Hi Guys,
Thanks,
Jamie
I'm not sure if I follow your correctly. But...
I'm assuming you have the SA manifolds removed but have the valves still threaded to the heads?
If so, they come out with a metric allen wrench. I forget the size, but if you look closely you can see the hex pattern.
Threw me for a loop, too.
Old Dec 30, 2009 | 09:53 PM
Gordon Bombay's Avatar
you can also put a wrench on your SAI plugs. mine were easy to get out. be careful not to warp the copper pipes running to your valves though
Old Dec 31, 2009 | 01:34 PM
humroot's Avatar
Right you are! It actually says right in the RAVE manual that it is a 9mm hex (i missed that step). So I went to the store today for a 9mm hex and might as well asked for 9mm Luger ammo cause there are none to be found. All the sets I saw go from 8mm to 10mm. So I got a set of impact swivel sockets and finally got the head bolts off. Once I had the heads off, i removed the valves with a adjustable wrench.
By the way, the RAVE manual says to remove and discard those little valves for the SAI. The Dealer wants $50 a piece for those and they are special order, so I am reusing mine.
Elley
Sep 18, 2015 03:09 PM
focusontheworld
Oct 21, 2012 01:00 AM
DiscoIIBrandon
Oct 9, 2010 09:41 AM
d.m.disco
Apr 24, 2010 06:54 PM
IDAHODISCO
Sep 13, 2008 03:19 PM
