Removed SLS, quick question
Old Mar 13, 2011 | 10:16 PM
svntsvn's Avatar
Default Removed SLS, quick question
It appears that the sls is on the same fuse with something else, will the pump continue to run if the car is driven or battery connected? I just want to make sure that I dont burn out a good pump, or it wont drain my battery.
I realize to get the light off, I have to take it somewhere with testbook, will this also solve my issues if the pump will remain on? Is there a short term solution for my drive to the shop if that pump does remain on?
Thanks!
Old Mar 14, 2011 | 08:20 AM
Bundu's Avatar
Banned
The pump will continue running, you need to get SLS deleted with testbook. You can pull the SLS fuse for a short term fix, also zip tie the height sensors to the body.
Old Mar 15, 2011 | 02:16 AM
svntsvn's Avatar
thanks. think i'm going to pull the power at the pump, the fuse seems to share the anti lock brakes and I dont feel like paying the shop 100.00 to do it. Even the non dealer rover guys here are lame, they told me it would take 1.5 hours. hahaha.
icyhot201
Aug 16, 2010 07:24 PM
richief556
Jul 23, 2009 08:29 AM
endneu913
Nov 3, 2007 03:46 PM
Darover
Feb 12, 2007 08:33 PM
