removing fuse
disconnect the light switch to see if it goes away. if it does its the switch and beyond. If it doesn't its from the fuse to the switch. to eliminate the switch put a jumper on the connector on c201 pin 3 brown/green wire and then jump the circuit to the switch pin 3. then ground pin four at the switch to see if it goes away. if it does go away its past that. if it doesnt then its the switch. Chances are its the switch itself. the switch itself needs to be open to ground the power.
Blakesrover
02-21-2013 01:43 AM
hecareth
02-20-2005 11:31 PM
