Removing radiator; How do we un-couple the transmission cooler lines from the cooler
Old Aug 13, 2013 | 09:32 AM
bcolins's Avatar
Default Removing radiator; How do we un-couple the transmission cooler lines from the cooler
The radiator is ready to come out of my 2003 D2.....EXCEPT......the oil cooler line on the drivers side is holding the cooler on to the radiator (there is an aluminum tab on the cooler that slides in to a provision in the plastic radiator tank. The tab and oil cooler line keep the cooler from being removed from the radiator). I Don't see any way to get the radiator out without releasing at least the driver's side Trans oil cooler line.
I've read the Rave,.............and like most..........am still unable to figure out what part of the coupling we "Push" and in what direction we push it to allow the coupling to separate.
Also,.....my truck has Supplemental Air injection,......does this in any way effect what radiator I need to order?
Thanks in advance
Brian in Austin
Old Aug 13, 2013 | 10:08 AM
Snafu / Disco Fries's Avatar
Gently push the line in towards the cooler, while pulling back on the collar around it. Pulling back lets the pressure off the 3 or 4 teeth type things that hold it on. When putting it back on, make sure you here a solid "click", and give it a little pull to make sure it attached right to avoid a mess in your engine compartment. Might not be a bad idea once it is off to slightly bend those teeth a touch for an even better grip.
Old Aug 13, 2013 | 11:59 AM
When reattaching the line, make sure you really clean both the connector and the pipe so it won't blow off while driving.As far as buying a new radiator, buy one that can adapt to the SAI.
Old Aug 13, 2013 | 12:05 PM
ralphobell's Avatar
When I changed my Radiator there was no nead to remove the Transmission or the Oil Coolers. Is it different on the 03 & 04 models?
Old Aug 13, 2013 | 03:25 PM
bcolins's Avatar
Situation Normal All * Up,......thanks for the tips. It did finally release. I pushed the cooler line end towards the cooler, and pushed the plastic round clip in the opposite direction,..............towards the cooler line,......then,....while holding pressure on the cllip,...I pulled the cooler line back,................and out it came. It took a few minute to figure that out.
I was "Pulling" instead of pushing the clip at first.
BC in Austin
Old Aug 13, 2013 | 04:07 PM
ralphobell's Avatar
Brian,
I'm in Round Rock so if you ever need a hand let me know. I have an Amigo and Autel if you ever need to check your ABS.
Old Aug 13, 2013 | 05:56 PM
Madlands's Avatar
I've changed the radiator in facelifted (03-04) and pre-face lifted(99-02). I've never disconnected the transmission cooler lines. I feel like you can do the job in half the time if you aren't having to mess with the transmission cooler.
Old Aug 13, 2013 | 06:41 PM
bcolins's Avatar
Brian,
Good to know. Is it Ralph?
I sent you a PM with contact info. I'm in Cedar Park.
Brian
Prozachd
Mar 22, 2015 08:41 PM
Rover Nick
May 1, 2014 08:40 PM
outdoor7or24
Jan 14, 2014 10:31 PM
marlmart
Aug 21, 2012 02:08 PM
s10lowrider1994
Dec 5, 2011 08:13 PM
